Danster Posted May 24, 2022 Share Posted May 24, 2022 Hi all, New member here and have ran into a problem with my 2.0 TFSI Black Edition S Tronic 3dr. There seems to be a leak somewhere, with my coolant empty 24H after filling it up. I have attached pictures of where I can see a pool of liquid and was just wondering if this is a common occurrence and an easy fix or if its worth taking to a mechanic. (Don't really know my way around cars at all) Thanks in advance Quote Link to comment Share on other sites More sharing options...
Steve Q Posted May 24, 2022 Share Posted May 24, 2022 53 minutes ago, Danster said: Hi all, New member here and have ran into a problem with my 2.0 TFSI Black Edition S Tronic 3dr. There seems to be a leak somewhere, with my coolant empty 24H after filling it up. I have attached pictures of where I can see a pool of liquid and was just wondering if this is a common occurrence and an easy fix or if its worth taking to a mechanic. (Don't really know my way around cars at all) Thanks in advance Id be getting it to a garage pronto as the rate of coolant loss is extensive. 1 Quote Link to comment Share on other sites More sharing options...
cliffcoggin Posted May 24, 2022 Share Posted May 24, 2022 No coolant loss should be ignored, particularly one as bad as that, unless you want to ruin the engine. As you don't know your way around cars I agree with Steve that it should be taken to a garage as soon as possible. Quote Link to comment Share on other sites More sharing options...
