  • 4 weeks later...
The relay itself is bad, probably corroded internally and shorting out. Replace with another relay.
Hello Chris,
Should be listed in your Owner鈥檚 Handbook.
Gareth.聽
Hi Chris聽
did you find out what fuse was for your windscreen washers? My screen washers aren鈥檛 working but headlight and rear washers are working ok ,wondering if they are on different fuses.聽
If you got yours sorted can you let me know 馃憤
  • 5 months later...
On 10/18/2022 at 9:56 AM, Chris Tucker said:
Hi looking for the window washer pump fuse Audi 2017 s3聽
Anyone got the fuse number/ location?
Hello Sam,
As I suggested to the OP - it should be listed in the Owner鈥檚 Manual.
I guess you know the bonnet has to be shut for the wipers (and washers?) to work.聽
So my car didn鈥檛 come with the physical or digital manual (bought it second hand) and from what fuse schematics i鈥檝e looked at i cant seem to find the specific fuse for the pump. The wipers themselves work fine it the water jets that aren鈥檛 working. The pumps aren鈥檛 even making a nose so i鈥檝e ruled out blocked jets, leak ect.
Cheers聽
Wouldn鈥檛 be surprised it鈥檚 on the same circuit as the washers.聽
Sounds like you are going to have to access the pump, and check the voltage to it.聽
  • 2 months later...
Hello Ben, and welcome.聽
I would simply do as I suggested, and get at the washer pump and check whether it is getting a 12v supply. Washer pump issues, and/or clogging of associated pipework is not unusual.聽
If indeed the fuse has blown, then that would be a more serious issue, since the circuit has been overloaded, and you will have to find the reason why - not as simple as just renewing the fuse.聽
Perhaps you could let us know how you get on Ben.
Gareth.聽
