billc Posted December 29, 2022 Share Posted December 29, 2022 hi ive posted this issue a last month , Ive another incident to add which i believe is connected - maybe it will possibly indicate something more specific . Ive been trying to find out . Ive 2010 audi a3 , usually runs well and has been recently serviced . For the last 5 months ive had an ongoing problem with restarting the engine - engine starts from cold ok - but after running and after I switch off it does occasionally take several attempts to start again Engine could be running 5 mins or 2 hours - switch off and try to restart a few minutes or a couple of hours later and wont - no pattern whatsover - instances are becoming more frequent . The engine turns ok but no firing takes place - I have to leave the engine for 5- 10 minutes between attempts other wise it floods After a few attempts engine starts immediately - like throwing a switch . no coaxing or spluttering involved . Its 1600cc petrol. Latest incident yesterday - accelerating coming out of a roundabout the engine lost power , the clocks were still lit up- I went down gears then after 6-8 seconds and before the car stopped engine kicked back into life and continued with my journey . Fortunate this time - but im sure that will happen again and may not be so lucky Does anyone have any suggestions as to what can be wrong? Quote Link to comment Share on other sites More sharing options...
cliffcoggin Posted December 29, 2022 Share Posted December 29, 2022 The same question gets the same answer. Get it tested. Quote Link to comment Share on other sites More sharing options...
Steve Q Posted December 30, 2022 Share Posted December 30, 2022 I'd recommend a diagnostic check Quote Link to comment Share on other sites More sharing options...
