Gearbox oil cooler pipe change
Hi,
My 2009 B8 automatic has an oil leak from these gearbox cooler pipes which run behind the engine. Does anyone know if they are possible to change without removing the gearbox?
Edited by Chris Churchill
These 2 pipes coming out of the oil filter.
  • 6 months later...
Did you find a answer for this as I have same issue
Hello Nawaz,
Chris joined and last posted on the same day some 7 months ago.
It would probably be better to send him a PM.
Perhaps you could let us know the outcome.
Hi thanks will do
