Suspected fly wheel noise??
Hi guys, cars started to make bit of a noise, I'm no mechanic but I've got a suspicion it's the flywheel "really hoping it's not" makes the noise when idle in neutral but when clutch is engaged no noise. Have attached small video clips. Any help would be appreciated. Thanks.
Hi sounds very much flywheel, it goes quite when you push the clutch in because that takes up the slack in the flywheel.
Thanks for the reply buddy, i feared it might be 😭 noise is the same but after a long drive clutch is starting to ride a bit
