A4 TECHNIK 35 TDI S-A(2019)-Reverse Camera MMI Display Fault
Hi All,
I have recently bought a 2019 A4 TECHNIK 35 TDI S-A and all was working fine until the reverse camera last week started showing a "fuzzy" picture on the MMI when the reverse gear was selected.
The following day the picture display returned to being normal.
However, 2 days later it returned to being "fuzzy" and has not returned to normal since.
The camera lens is clean so would appear to be a technical / software issue?
I have rebooted the MMI but that didn't solve the issue either.
Has anyone else experienced this problem?
Ideas to self fix or is it a visit to the local Audi dealership?
It almost looks like a faulty connection... like you need to disconnect the camera and clean the connectors and reconnect it.
What method of MMI reset did you use?
Touched the MMI screen top right corner with 2 fingers which rebooted the system into Engineering Mode.
Then exited the Mode and the MMI starts back up again.
