360 Camera System Failure
Has anyone experienced this or similar please??
  • Last night - reversed into garage - cameras all working fine.
  • This morning - driving out of garage - no cameras working. All four cameras were showing in the usual MMI display as a camera icon with a red diagonal line through them where usually there's the image from the camera.
  • Turned off the engine, opened and shut the door and the bonnet, restarted - now 2 of the cameras are working. Rebooted MMI, no difference.  I didn't leave it off very long though in these tests, as I needed to make progress on my journey.
  • 70 miles to work - still not working. 8.30pm coming home - all normal - all cameras operative.
The only thing I can think of is that after parking last night, I filled the windscreen washer and some water overflowed the spout (enough to run down under the car). Did something get wet and cause a failure?
Car booked in for a diagnostic check in a couple of weeks just in case.
Hi Mike,
I had exactly the same issue last weekend. This affected all cameras. Everything working fine when left home, stopped at a motorway service station for 10 mins and would not function on start-up. Got to destination and still not working. Car was left for 4 hours or so and then worked fine again when started up to drive home. No issues since or before.
I had used the windscreen washers on the journey a short time before stopping at the service, but had not filled them up recently. Weather was dry.
Be interested to see what your diagnostic check reveals. Intend to run one myself.
Hello J - thanks for reminding me to update this! Sadly no information from the dealership except "nothing wrong with it now, no sign of water going into something it shouldn't, some spurious errors about the camera system in the diagnostics, cleared the errors and please come back if it happens again"...
Would be interested to know what your diags come back with. I don't have the capability to do them myself, but I am thinking of investing in a scanner and learning how to do things like that.
cheers, Mike
  • 4 months later...
I have the same problem in Audi a6 2019. These are errors from the controller.
B127C04
B127F04
B200FFA
C12D8F0
Mstv did you solve your problem?
3 godziny temu, kotu powiedział:
Mam ten sam problem w Audi a6 2019. Są to błędy z kontrolera.
B127C04
B127F04
B200FFA
C12D8F0
Mstv, czy rozwiązałeś swój problem?
Thankfully the problem never happened again for me (so far), so I can't offer any further advice....
