Shafee Posted May 29, 2024 Posted May 29, 2024 Hi all, I have very recently purchased an Audi A3 35 TFSI Black Edition MHEV auto (brand new) and have found that it makes a high pitch beep sound from around the A pillar front passenger side. This occurs when I depress the accelerator and the brake. It occurs in all driving modes except for Sport. It happens when the MMI system is on or off. I took it into Audi and they basically said it was normal. See attached excerpt of report. I have alap attached a recording of the sound. I have emailed Audi customer services. In the meantime does anyone here have any ideas? Thank you Audi A3 Beeping.m4a
Magnet Posted May 30, 2024 Posted May 30, 2024 Many thanks Shafee, Pending a response from Audi Customer Services:- I would be booking this in to another dealer if this were mine, since your dealer is giving you every indication that Audi have knowingly ‘built in’ this annoying feature! Kind regards, Gareth.
Shafee Posted May 30, 2024 Author Posted May 30, 2024 Cheers - I’m thinking that’s what I’ll do. Perhaps not mention that the previous dealership said it was normal 1
Magnet Posted May 30, 2024 Posted May 30, 2024 Well worth a go, although I would suspect your visit to the first dealer will be recorded in the car’s on-line history.
Chainedtomato Posted September 26, 2024 Posted September 26, 2024 Hi, I have exactly the same on my 2024 A3 MHEV and other owners are reporting the same. Did you get anywhere with the issue? Thanks in advance
Shafee Posted May 27 Author Posted May 27 Audi checked it and said it was just part of the ‘characteristics’ of the car and that it was normal. But when pressed they couldn’t tell me what it was. By the end that’s all I wanted to know, but no luck. I’ve figured out that it only does it when you put revs on after the engine cuts off when coasting. Some sensor / signal relay perhaps.
Ljt Posted May 27 Posted May 27 I have the same on a Q3 sportback 2024. Audi have had it 3 times and have now told me that’s what it’s supposed to sound like. I said what Audi have purposely added a really annoying noise on an expensive car as standard. They did change the activated charcoal line in mine as that is a common issue as they split but it has made no difference. I have had other mechanics say it could be transmission, turbo, air intake timing belt/chain or electrical. I said to Audi what I don’t want is to come back when it’s out of warranty and then be told I have a big problem and it’s going to cost me a fortune. The thing is quite a few people have the same issue so there has to be a problem.
Blrr Posted 12 hours ago Posted 12 hours ago Hi did anyone ever find answers to this or have a garage find a solution please as I am experiencing the same with my A3?? Much appreciated
Ljt Posted 6 hours ago Posted 6 hours ago My q3 sportback has been to Audi three times. The last time they told me it was within Audi parameters. So I said, you are telling me Audi have built in this really annoying noise on a 45k car. I contacted Audi customer service and it is booked in again for them to have another look. I have said they should check the turbo as a boost leak would make that noise and also the the relief valve in the suspension pump. I will post if I get an answer. Hope you find out what yours is.
Blrr Posted 6 hours ago Posted 6 hours ago On 5/30/2024 at 10:03 AM, Magnet said: Many thanks Shafee, Pending a response from Audi Customer Services:- I would be booking this in to another dealer if this were mine, since your dealer is giving you every indication that Audi have knowingly ‘built in’ this annoying feature! Kind regards, Gareth.
Blrr Posted 6 hours ago Posted 6 hours ago 11 minutes ago, Ljt said: My q3 sportback has been to Audi three times. The last time they told me it was within Audi parameters. So I said, you are telling me Audi have built in this really annoying noise on a 45k car. I contacted Audi customer service and it is booked in again for them to have another look. I have said they should check the turbo as a boost leak would make that noise and also the the relief valve in the suspension pump. I will post if I get an answer. Hope you find out what yours is. Maybe coincidence but I found today that if someone is sat in the passenger seat or rear seat the beeping didn’t happen. Wondering if it’s something to do with a sensor? Does this happen to yours? Maybe it’s just all interconnected who knows at this point!
