Electrical static popping
Hello 👋🏻
I have an issue that happens at random. There’s a static popping/thud sound from the sub and speakers. Anything can trigger this, such as operating a window or the lights coming on, and even steering the wheel. Sometimes it can be a little crack, and others it’s a big thud from the sub.
this has only started when a new stereo was installed. I’ve disconnected any wires that aren’t relevant for operation. A simple yet expensive option is to change the unit, but I want to avoid that and see if anyone has experienced this before, and maybe solved it.
thanks!
One of the first things, yeah. But nothing happened when I moved things about.
No I don’t think so. I just connected the iso lead. And fed a live wire from the fuse box.
how would I be able to identify an earth problem? Could be a good place to start.
It’s certainly worth another try. Could just be a problem with the stereo itself. Thanks for your help.
