Tel19 Posted May 4 Posted May 4 I have an A6 C6 2008 Allroad. Suddenly while driving I got a long bleep and the ESP, ABS and suspension pump lights came on. I was driving back from Spain at the time so couldn't do very much but it didn't seem to affect anything. The ESP off switch does nothing now. I don't know if ESP and/or ABS are working but the suspension pump is still working even though the light is on. The only thing I have noticed different is that when using cruise control it no longer automatically brakes to maintain the set speed. It accelerates fine but does not slow the car down on a hill. When you first start the car sometimes there is a delay of up to 10 minutes before the lights come on and sometimes they come on immediately. I have visually checked all the fuses for the ABS and ESP and they are fine. I can't find any other posts which mention these 3 lights. Has anyone any ideas? All help appreciated, thanks.
spartacus 68 Posted May 4 Posted May 4 Scan the car with VCDS. Normally when the dash lights up like a Christmas tree it’s a wheel speed sensor.
Tel19 Posted May 5 Author Posted May 5 I can't get my scanner to finish the scan. It is a VAG305 which says it is compatible with the C6. I can't remember if I used it before on this car or an earlier model. Just before it completes the scan I get "linking error". I have tried all the suggested methods to get round the error but still get the same message.
