Q5 Brake pad wear indicator fault
Good morning 🙂
Hopefully someone could offer some help regarding my issue regarding the brake wear indicator warning light .
It started last year intermittent then on at all times . I got the front pads and sensor changed light went off at least for a while to then return a few months later. At this point I went back and bit the bullet to get the rear pads changed to no avail my mechanic suspects a break in the cable . He is an old school mechanic so freely admitted wiring isn't his strong point . My father in law is pretty decent and we had a go checking what we could . Has anyone had this issue before and if so what did you find .
Thanks in advance
Jamie
Did you have the sensors changed on the rear when replacing the pads? I would imagine a diagnostic will be able to point you in the direction of which sensor is throwing the code.
Thanks for the reply .Yeah we changed them on both and even tried linking out . We put the scanner on with no results unfortunately 🥴
