Rear reversing led bulb recommendation
Hi All
my car is a 2010 1.4 tfsi 3 door
has anyone successfully used a led for rear reverse light ie no warning on dash (canbus error)
if so what bulb did you use?
many thx in advance
Dave
Solved by Davegoorn
I fitted these
P21w 1156 Ba15s LED Bulb White 6000K 6W 12V-24V DC10-30V Super Bright for Reverse Light Brake Turn Signal RV Interior Light Auto Backup Rear Fog Lamp Stop Drl Tail Position Bulbs Rear Fog Lamp 2 Pack : Amazon.co.uk: Automotive
Absolutely no problems or errors and they're a huge improvement over the originals, like day and night (no pun intended. My A6 is a 2003 though so possibly may not be as fussy as newer models?
Thx for your quick response I will have a look
  • Solution
IMG_5119.thumb.jpeg.f83b5a10efb5567442dfa9b29bbf0f88.jpegHi guys I found a reversing bulb that doesn’t throw up a fault code on my dash on my 2010 A3 8p it’s made by Aslent (China) it’s a P21W fitting
Bet you can't wait for it to get dark so you can try them out! Seriously though, they make a huge difference.
Smiles your not wrong it already looks so much better
happy days
