stu.waller Posted May 30 Posted May 30 Hi All. Would really appreciate some support with an issue that has confused audi specialists. The MAF sensor keeps on blowing. When it does the car cuts out. Unplug the sensor, the car runs ok, but over fuels. Putting a multimeter on the ground pin in the wiring plug, the next to the middle pin I get 4.99 volts which I think is correct. If I them check the next pin I get 7.3 volts with ignition on and 9.5 volts with the engine running. I thought this was supposed to be considerably less? If that's the case any ideas where to start? Anyone know where I can get a schematic for the actual ECU? I'd like to track back through the loom and find where the excessive voltage is coming from. All help will be very much appreciated. Stu
stu.waller Posted May 31 Author Posted May 31 So an update on readings. Been back out to do a better job of recording voltages. Multimeter on car ground to the following pins: with ignition on but not running Pin 1- 4.98v Pin 2- 0v Pin 3- 12.19v Multimeter on car ground to the following pins: car running Pin 1- 4.99v Pin 2- 0v Pin 3- 14.37v - 14.45v when rev'd Variance between pins 1 and 3 - 9.3v And pins 2 and 3 - 14.4v All seems normal yet something blows the maf sensor. Could the Multimeter response time be insufficient to pick up voltage transients? What am I missing here? If anyone could provide their voltage readings as a comparison it would be appreciated. If anyone has any ideas of what to look at next, that'd also be appreciated. Would different measurement equipment be more suitable? Oscilloscope?
stu.waller Posted June 1 Author Posted June 1 So I think that pin 1 is sending 5v from the ecu to the maf in error. Does anyone agree? Pic attached shows pin 2 as ground. Pin 3 routes to B277 positive connection 1 in wiring harness. Pin 2 should be for maf to to send voltage to pin 22 in ecu, not send 5v to maf sensor. So what feeds pin 22? Anyone understand where in the ecu it can produce the 5v? Or where else in the system 5v could be fed into the ecu which is then going to the maf? It'd be good to know what other wiring I can investigate that could be causing this. 1
cliffcoggin Posted June 1 Posted June 1 It's unfortunate that nobody here has been able to help Stuart, but please let us know of progress. 2
stu.waller Posted June 1 Author Posted June 1 Update - received my obdeleven today and plugged it in. 3 persistent faults. MAF - understandable as unplugged Fault code 01314 Fault code 01592 Anyone think that either of these could contribute? Could 01314 be due to maf being unplugged? 1
stu.waller Posted June 3 Author Posted June 3 New MAF sensor installed. Both fault codes cleared. Only problem will be how long the MAF sensor lasts this time. If anyone has any thoughts on where to fo with loom investigation that'd be appreciated. 1
Solution stu.waller Posted June 21 Author Solution Posted June 21 So it seems that replacing the air quality sensor has resolved the issue. Don't ask me why but it is now sorted.
cliffcoggin Posted June 21 Posted June 21 Is it possible something you did has secured a poor electrical connection caused by corrosion/weak spring/unfastened clip etc?
stu.waller Posted June 21 Author Posted June 21 It is possible, but the air quality sensor was short to ground and required replacement. I'll post on this topic at a later date if it manifests again along with anything else that ends up being worked/replaced. The garage I spoke to said that a car they had in had all manner of issues due to an air quality sensor failure. Affected rear camera and all sorts. Personally I don't like faults you can't turn on/off as there is still the uncertainty. Unfortunately I'm not in that position so have to live it. I've completed over 500 miles since so feels promising.
