poolielad Posted May 31 Posted May 31 Hi guys, I have a 2010 Audi A3 S-line........ I have a Airbag light which wont go away, any ideas please?? I have just changed the Heater blower motor so I guess one of the connections to the glove box which I had to remove was for the airbag, but all put back together now and its still there!!
daveyboy1967 Posted May 31 Posted May 31 I used to keep getting the same problem on my '04 A3. It used to happen every time I gave my mate a lift (putting it politely he's generously built). Turns out when he put the seat all the way back it was undoing the connector under the seat. Could be worth a look if you put the seat back to work on the blower. 1
Steve Q Posted June 1 Posted June 1 As Dave has said it's often a loose wire under the passenger seat. 1
Rybrook Posted 14 hours ago Posted 14 hours ago (edited) Yes it's the multi plug on the glove box, I had this just the other day, I was messing about with my head unit, while I had the glove box removed the light on the dash and in the binnacle were illuminated, the glove box had the passenger activation key switch inside. Switch off when connecting it back up Edited 14 hours ago by Rybrook
poolielad Posted 4 hours ago Author Posted 4 hours ago 10 hours ago, Rybrook said: Yes it's the multi plug on the glove box, I had this just the other day, I was messing about with my head unit, while I had the glove box removed the light on the dash and in the binnacle were illuminated, the glove box had the passenger activation key switch inside. Switch off when connecting it back up What switch is this, and where about is it please??
Rybrook Posted 3 hours ago Posted 3 hours ago When you remove the glove box, the is a cable connected near the footwell light, has 5 wires I think, this connects the footwell, glovebox and this
