Air Con help plz
Hi all need some help if possible I have a 2017 Audi A5 coupe 2.0td slim
I have a problem with the air con
When I turn it on it doesn't get as cold as it should be you can feel a little difference in temp but only on the drives side and at the rear the passenger won't push any air con out  just normal air
I know it not the gas as I had it re gassed about a month and a half ago with no issues
I have ran a scan on the car and I do get a fault but got know idea what it is please see picture attached
Any help would be great thanks
Welcome Clifford and thanks for joining.
Sorry, but I’ve no idea about the long code, but probably worth searching other threads on air con. issues which were attributed to an inexpensive pressure sensor - I think.
Having said that, a family member had their compressor changed at great expense and to no avail, so I would be tempted to first seek advice from a VAG independent and/ or an Air con. specialist.
Might well be worth trying the pressure sensor first - a low cost option.
Hopefully, someone else will come up with more advanced responses.
Regards,
Thank you for your reply
Is the pressure sensor the same as the turbo pressure sensors or is it something different
I will have a look into it love the car only owned it since last year love the drive just the odd little problem I am having
Will defo get it checked as it getting hotter and I spend a lot of time on the motorways so defo need to be done
The code that comes up I have looked around and all I can find is that code for a different system not the air con
It a strange one and will update soon as it sorted I hope
Yes I have had a look here and on other places to could not find anything
I think it something to do with the blend door vent thing as on drive side you can feel the air con slightly but passenger side just stay on what ever the temp is set to with no air con
