I have  a 2015 A4 Avant Quattro 2.0TDI Technik. The cruise control has ceased to function and the Cruise Control and distance sensor light (which normally  lights green when engaged) is permanently red. My local independent VAG garage in Northampton have diagnosed the fault as the Radar Camera. They have quoted £3000 for a replacement. They say second hand ones won't work as the camera has to be programmed to the car. Can anyone help ? Is there someone who does reconditioned ones? Is the one on the car mendable?
Many thanks. George
Sorry to hear of this situation. I believe the garage are telling you the truth. Bit on the safe side you could always get a second opinion
Thanks Steve - actually this was the second opinion as our local garage suggested the same but recommended I go to a specialist to confirm. I was hoping there might be some work-around like a reconditioned unit or some sort of part exchange. As the car itself is probably only worth about £7k if everything was working, I am not keen to spend half the car's value on one bit.
Hello George,
How often do you use the CC?
I only ask since I’ve had our non-Audi for 3 years and I’m yet to use it despite doing fairly long runs.
As you say, with an anticipated bill of c half the value of the car, can you do without it?
