Warning light
Hi there
Could someone tell what this light means that has come on please?
Solved by daveyboy1967
The green symbol, sorry, question mark not working on keyboard.
Yes,I can't find any answers.
  • Solution
It's the DIS Efficiency Programme light, nothing to worry about. It just relates to things the effect your MPG, stuff like using your AC etc.
Thank you very much,I was just bit baffled with it.
This post was recognized by Steve Q!
daveyboy1967 was awarded the badge 'Great Support' and 50 points.
"Great advice"
A bit more info for you mate.
Efficiency mode is a mode designed to optimize fuel or electricity consumption and maximize mileage. In this mode, throttle response is subdued to reduce power consumption, and the AC system is put in ECO mode. Throttle, transmission, differentials, adaptive cruise control, and even climate control parameters can be managed to reduce mechanical resistance and improve efficiency. You can use Drive Select to pick Efficiency and get the most efficient group of settings, or use Drive Select to select Efficiency MODE, turn the car off and on, and you will get "Not Quite As Efficient Efficiency Mode".
