Chisy Posted 3 hours ago Posted 3 hours ago Hey all. Hope it's ok to ask for a bit of help here?! I have a 2018 S4(B9) but have developed a fault with my air con. The code I got was B109207 so believe the motor has gone duff with my air con recirculation flap motor. I do also have another fault code which is B11AF07 "Fresh air door motor mechanical malfunction" but not sure if they are linked but 2 motors failing at the same time would be mighty unlucky. If I were to buy a new motor and fit it, is there someone in the central Scotland area that can help me recode/activate it using VCDS as my Carly scanner can't do that. I begrudge going to a main dealer as they charge so much for what I think is a simple job. Cheers, Chisy
