Zammo Posted 4 hours ago Posted 4 hours ago My indicator for right turn flashes to the left when switched on for first few flashes then heads over to the right side. need to check the connections to try and fix the intermittent issue. Have looked in both fuse boxes and behind the hazard cluster on the dash? thank you
Steve Q Posted 2 hours ago Posted 2 hours ago If it's like my a6 the relays will be at the back of the fuse box on the driver side. You access it by removing dash trim under the dash near the steering wheel.
cliffcoggin Posted 1 hour ago Posted 1 hour ago Check the earth connections at each light. That is a common cause of defective lights.
