Can this alarm be bypassed?
I've got a problem with the alarm in that I have to get right next to the alarm unit under the bonnet to arm and disarm it. Everything works once armed and it disarms properly as well. I've changed the batteries in the key fobs but the problem remains. It could be some dry joints on the key fob's PCB as that gets pressed quite a bit when activating/deactivating the alarm.
I want to remove the alarm unit so I can check that too but, if I do that, the car won't start. Looking at the alarm diagram, is it possible to jump the YELLOW-RED and the VIOLET-BLACK wires on the connector so the car starts with the alarm unit removed?
Thanks!
