Rear bumper tow hook cover
Hi all ,have not posted for a while. I have 2007 A3 s line sports back and I am trying to locate the correct rear hook cover. I suspect the bumper has been changed to a different year as when I removed it to fix parking sensors, I noticed bit of damage on rear frame structure. I have tried the actual year of the car and got a small cover which I thought was a front but is the later rear one.I will try and add pictures in the hope that someone within the forum recognises the bumper or has changed it themselves. I thank you all in advance and hopefully I can get an answer. I look at all A3,s as I follow them trying to see the same one. Will add its flat with no contours.20250814_174622.thumb.jpg.25d937eb8c0eb89250b0e28da0b9b83b.jpg20250814_174659.thumb.jpg.5c57e6f381233e29053a917e33cea3df.jpg20250430_194601.thumb.jpg.ff9498d126b6c44b883a37bc0547a102.jpg
I think he is after the cover, which hides the mounting
point, where you screw in the towing eye.
Brian.
Hi all ,any ideas on the above tow eye cover? I am sure someone has the same bumper?
