A3 8pa driver window issue
I'm after a bit of help.
I have a 58 plate 1.9tdi. The drivers window doesn't work. I have rewired the door wiring twice, tried a new secondhand motor and master switch. The results are the same. You can hear a click coming from the motor circuit board, but no motor movement. It only clicks when pressing the switch down, not clicks when pulling it up. Wiring inside the door looks ok although I've not stripped the wrapping all the way to the motor, just half way.
Thanks in advance.
