Ad blue system fault no restart
Hi there I've a6c7 ultra engine code ddda recently I've got this yellow warning on dashboard so I've scanned for engine faults no luck i did some research i did top ad blue tank reset the scr tank level and the scr lock the I've checked the pressure ad blue 5 bar did some tests with ad blue injector tried to do inducemennt system reset no luck at all I did some dpf regeneration no luck also I've checked the nox sensor upstream and downstream and I've got some results upstream it seems to be fine but downstream it's showing on system not installed so I'm wondering if that could be issue with warning
Any thoughts thank you in advance
