Audi A4 1.9 SE TDI B7 gremlins and issues
Hello all,
running down a few gremlins been a hell of a day.
had some issues with condensation, found that the bulk head drain was clogged causing water coming into the passenger footwell.
ive now drained and cleaned the bulkhead but had to drive to work so haven’t drained and dehumidified the interior.
today on the way to work I hit a rather large puddle, killed the car for about 15 mins and now no longer have any use of all of my windows.
in addition my key will no longer sync to the car. I’m assuming the CCM has drowned and needs to be replaced. As for the windows, it doesn’t work if I put the key in the door and hold it locked so I’m assuming the fuses may be gone. Any idea from any on the issues?
I did also have a beeping coming from the rear while I was driving which is what I believe is from the CCM being toast.
GET YOUR SELF SOME  RICE   FEW BAGS  BUD  PUT ALL OVER CARPET PASSAENGER SIDE  LIVE IT FEW DAYS AND WATER GETS SOCKED UP    THEN DO IT  AGAIN  COMMONG FAULT WORKED FOR ME  5 TIMES NOW
Yeah imma pull the CCM out in the morning chuck it in some rice and then soak up all the water
