Fuse location
Hi, can you tell me where the fuse is located for the screen wash pump, thanks.
Wayne
Should be shown in your handbook Wayne.
If you find it’s blown, then it has done so for reason, and that reason has to be found first.
Common issues:-
Clogged washer bottle outlet. Blocked tubes. Bad connections onto pump. Failed/clogged pump.
You haven’t explained your issue, so we don’t know what you have checked so far.
Regards,
