Can some tell me what this means please?
Just popped up as I was driving?? Its flashing on and off.
Edited by poolielad
Likely to be be glow-plugs (coil symbol) and an engine management light. As long as it's not permanently illuminated. Car will need to be scanned to see the actual fault(s) which will provide more details. If it is glow-plugs, be wary about just heading in to replace. The engine needs to be hot and spray PlusGas on base of plug 2-3 days before attempting to help ease. Only use 3/8" or 1/4" ratchet and deep socket. If the plug breaks you're in a world of pain. Not sure what's spec these days, NGK, Bosch, Beru? When renewing plugs, use a light smear of ceramic grease on the threads.
I'd also check battery voltage. At this time of year - you will get issues with batteries, and ones that are heading out due to age or cold cranking degradation. Should be around 12.6v not started. New one, likely AGM will need coded to the car - if that was a feature - noting A3 is 2011.
