Camshaft adaptation value
Hi guys,
I recently purchased an OBDeleven device and scanned my car. It's showing fault code P191A00.
I checked the camshaft adaptation (Bank 1) value, and it's reading between 0.70 and 0.86°, which seems to be well within the normal range.
Could this still indicate a faulty crankshaft or camshaft position sensor, or is the issue likely to be something else? Would it be worth replacing either sensor, or are there other checks I should carry out first?
Any advice would be appreciated. Thanks!
