B7 door blades
Hi All ,as a new member I would appreciate any links to a video or detailed explanation as to how to actually strip a bulging front door blade. I have seen a u tube video in 3 parts but the actual detail and camera usage is bad . Thanks Rosslyn
Why not post some pics of the problem and the YouTube video link?
The video I referred to was by performance concepts 5 years ago. However it lacks detail and camera usage is bad
The door blades are the protruding trim at the bottom of each door. They are slightly different shape depending upon the model   Mine is the s line shape and I think the type of fixing changed with the years. Again I would like details from anyone who has actually taken them apart
Rosslyn, use this link to ID your model and part. You can get the proper part number from it. This is a brilliant resource I found from a member of this forum’s post. I’ve found parts for mine which I could not anywhere else using it.
https://www.lllparts.co.uk/catalogs/audi/RDW
I hope this helps,
Sean
Hi Sean Thanks for that link . It looks to be very useful. I am hoping to be able to repair my door blades.  Regards Graham
