P0141 Bank 1 Sensor 2 RS3 3018
Hi all, plugged the car and came up with a P0141 O2 Circ Heater Bank 1 Sensor Malfunction. From what I’ve been reading it’s the sensors after the Catalytic could anyone confirm? And if you know where I can get a replacement one and part number?
Many Thanks Ryan
Couple of links here for 2018 model. This is European build.
https://www.lllparts.co.uk/catalogs/audi/RDW/RSQ3/764/2
https://www.lllparts.co.uk/catalogs/audi/RDW/RSQ3/764/9/906/906000
Looks like Lambda O2 probe after catalyst is 07K906262B, Bosch part. Double check this via Audi parts. £186.50. Can get that for half the price I'm sure via Autodoc, although you might be looking at 10 days or so. Check wiring though, as the sensor may be fine. VCDS handy for this type of job. If you disconnected cable to sensor before catalytic convertor, then that would trigger DTC error, if you're trying to pinpoint one or the other.
Edited by spartacus 68
