Steering column combination stalks
Hi all,
my stalk cluster seems to be playing up, seems to only be the side that controls the wipers/washers. Seems intermittently loosing the screen wash function and swapping it to activating the rear wiper.
is there somewhere I can find the part number so I can find a replacement unit without having to take the wheel off to save myself some effort?
cheers.
You may just be easier going to a dealer or TPS if you have a local one as there are many different versions depending on equipment level and they will advise using your vin number. The squib ring you need has component protection as I found this out when a customer supplied there own second hand
Cheers Sid,
I take it I could use my existing squib ring, unless the issue is in the ring?
They come as a complete unit unfortunately unlike some other brands.
I’m assuming the squib ring is item 2, as TPS will sell me just item 1, but annoyingly they won’t give me the part number lol.
looks like I’m popping off the wheel & cowling to check the part number.
Yes 2 is squib ring/steering angle sensor
You might be lucky and get away with a 2nd hand unit as the ones I’ve done have come complete with squib so that’s what likely has the component protection not the stork unit. The difference in part numbers relates to features like lane asist, cruise control, active cruise control and rear wiper. If the storks on eBay have exact features as yours then it should work
I think, liking at images it’s just a screw and some clips that connect them, along with a couple electrical plugs, so should be easy enough to swap over…
famous last words.
Mines got active cruise, lane & rear wiper, so will probably limit the number of them out there.
I think you’re correct because that is a rare spec. Just remember to disconnect battery and have steering set straight ahead and steering angle sensor doesn’t rotate when wheel is removed and all will be good
