Ignition fault
Help my a3 tdi has fault, starts OK but speedo, rev counter , mileage heater plug light airbag & abs light stay on can anyone advise suggestions??
Solved by cliffcoggin
It's likely the instrument cluster has failed, a common fault on A3s. Companies such as ECU testing amongst others can usually repair it for less than ÂŁ300. You will need to remove the cluster and post it to them.
  • 2 months later...
On 2/21/2026 at 6:44 PM, cliffcoggin said:
Was the reply of any help to you Steve, or did I waste my time writing it?
Thank you great suggestion cured the fault it was as you suggested the cluster 👍
this usually isnt lots of separate faults tbh 👍
on A3 TDI when speedo + rev + ABS + airbag all stuck on, its often CAN / power issue or ABS module not waking up
