boot wont unlock using remote
Hi all
I have had the body control module changed due to it failing. I now have an issue with the boot won't unlock with the remote keys. Everything else works on the remote. The boot lock will unlock with the key in manual. If i put voltage onto the output from the module in the boot it operates the lock. Using VAG software and trying it on test open boot lock manual it does not operate the boot lock. Tested all wiring through the boot trunking and all wiring checks out fine and no crossing over of wires etc. No fault codes are coming up. Am i missing something in the setting somewhere? any ideas? Thanks Steve
