Rs Q3 brakes.
     Hello,
I will be needing to replace the seemingly dreaded front discs / pads soon on my wifes RS Q3,registered January 2015. The prices seem scary for genuine parts but i have had performance cars for 30 years so i shouldn’t be shocked!
Can someone give advice on the best place to look for these items?
i have no issue using aftermarket parts as long as they are of a very good standard but if genuine is the way to go,where is the best site?
Thanks.
Craig.
Quick check on LLL parts, looks like the scalloped rotors, originally made by Brembo and weigh the same as a ship’s anchor! Part number: 8U0615301A and pads are 8U0698151J. You can double check that against the last time they were done, but they are expensive.
https://www.lllparts.co.uk/catalogs/audi/RDW/RSQ3/764/6/615/615050
Not sure when they were last changed, but for arguments sake, say 30k, then that’s another way to look at it if it gives you another 3 years based on average mileage.
You really don’t want to cut corners when it comes to brakes, especially as it’s a performance car.
Zimmermann apparently do rotors and pads for the RSQ3 (not scalloped). Just watch if you buy from Germany as you’ll have taxes on top too.
Lastly, don’t write off Audi parts, ask for discount, it’s a 2015 car, they might take pity on you.
           Thanks Spartacus,
I don’t cut corners on any car parts but was just hoping someone might say ,try this after market brand,they are brilliant!
I will bite the bullet when the time comes and get the branded parts.
