Heater & air con control unit
Hi all, I've recently replaced my console heater and air con unit and I'm getting a protection code being thrown up🙄(fkin Audi's)from what I understand as it's not the original unit from when the car was built it doesn't like it, auto electrician cand sort it neither can my mechanic.
2009 Audi A5 Cabriolet 2.0 tfsi
Any suggestions/help massively appreciated!
Assuming it's component protection linked to ECU. That said - car is 2009. Quick search suggests this started with A6 and A8 back in 2005, which you can only over-ride with dealer level software such as ODIS.
This video is quite a good example to swap data across damaged unit and the second-hand part by copying the data from the EPROM chip.
Thank you👍
