Help needed - Ticking noise coming from behind dash
Hello,
I am hoping if anyone would be able to help explain what may be my issue
I have a 2014 Audi A3 1.6 TDI and recently iv been hearing a ticking noise coming from under the dash when I start my car which stops after about 30 seconds and only comes back on when the air recycler button is pressed iv removed the glove box and can see the ticking happens when what looks like the air condition flap opens iv attached a video of what’s happening.
Any help would be greatly appreciated.
Okay thank you I’ll have a look into that, the only thing that’s confusing me is that the flap opens and closes it’s just when it is open it seems as if it’s getting caught on something and I would assume the motor works if it opens? Or is this not the case and it will still be a motor issue ?
  • 4 weeks later...
this sounds like one of the flap actuators. I’ve had 2 audi a3’s and both have had this issue. Very annoying problem. If you have an obd 11, give it a scan and it should tell you if your flap motor is bad.
