A5 parking brake module
Hi my stepdaughter has a 2015 A5 it has come up with parking brake malfunction on the dash , handbrake works fine so obviously the module ,have tried clearing codes not worked so have seen a new module for the car but does anyone know if it is just a plug in an d go job or will it need coded to the car thanks
Hi if its a new module it will need coding to the car but if the brake is working it can't be that, what're you trying to clear the code with?.
