2009 A4 emissions light - Error code help?
Hi All.
I am new to the forums, so I apologise if this doesn't read too well, but looking forward to helping people out in the future.
I have a 2009 A4 2.0 TDi S-line 170ps 6-speed manual Start/Stop - Current mileage 134500 (NOT QUATTRO)
Previously, I had a problem with a failed DFP sensor, which cost me £50 by the roadside, nearly 2.5 years ago. (Just after I had it)
Whilst on my home on Saturday, I had the Emissions Control Light come on again. :unsure:
So, after the information i had from the VW Audi RAC guy who attended last time, I decided I would not risk driving it so I wouldn't risk clogging the DPF, just in case the same sensor had become clogged or failed.
However, I have had the car plugged in at the garage today (my old VAGCOM cable I had wont talk with my car) and it has thrown up a number of error codes on the intake side. This came as a kind of relief that the DPF isn't dead.
The car has been running fine the last few weeks and has been driven over 1000 miles in the last 2 weeks, mostly motorway driving.
Servicing is done on a long life service, as and when required with castrol edge oil. Air filter was replaced on the last service. Fuel filter was last replaced on the previous service.
I have looked up the codes (detailed below) and wondered if any of you guys could shed any light on it.
The garage has cleared the codes and advised they will re-check when it goes in for new brakes on Friday. :wacko:
ERROR CODES:
P1603 - Internal Control module Failed (Think this was caused by me trying my old cable)
P15A1 - Neutral position sensor
P15A1 - Neutral position sensor - Implausible signal
P2008 - Intake manifold flap
P2009 - Electrical Malfunction
P010A - Mass Air Flow
P1016 - Valve for Air Filter Bypass
The below is some further info I sourced off the web and I apologise for the way it is written, but I had to convert the info from Dutch to English.....
Error code decriptions:
Error Code: 18440 P2008
  This error code is " Generic OBD " ( for each automaker same description and meaning).
  The following symptoms / causes / solutions are specific to VAG cars ; to other car manufacturers who may differ in detail.
nl Valve Intake Manifold 1 Airflow Control for electrical fault in circuit
du Saugrohrklappe 1 für Luftstromsteuerung elektrischer Fehler im Kreis Strom
and Intake Manifold Flap, Bank 1 Circuit / Open - MIL On
Additional information on the error codes
Possible symptoms :
    ERROR lamp (MIL) lights
Possible causes:
    Fuse (s ) are poorly connected or defective
    B + terminal 30 and B + terminal 15 is defective
    Valve is contaminated
    Valve is stuck
    Wiring and / or connections to / from the control valve defect
    Valve control does not work (properly)
Possible solutions:
    Check / replace fuse (s)
        remove the fuse (s) out
        Make the ends of the fuse (s) clean (very light sanding with fine sandpaper , then very little contact spray on it)
        fuse (s ) by measuring with a multimeter ( the fuse (s ) sometimes looks fine , but appearances can be deceiving )
        fuse (s) replace / replace
    Check B + B + terminal 30 and terminal 15
    Check postition valve ( measuring blocks ) / Replace Valve
    Disassemble the valve and clean him
Extra info :
    These are the valves in the intake manifold. These sit there for part load, a tdi has through this way stratified
    combustion = more economical. link , link . So to see something with the adjustment.
    Flashy nothing serious as long as they are open , it does not cost . And in consumption also is not so bad .
    This gives no lights etc in the dashboard. If you have full power , you can just drive
Layout Code : P15A1
  This error code is " Manufacturer Specific " ( for each automaker a different description and meaning). The following
  description / symptoms / causes / solutions are specific to VAG cars.
nl Sensor Neutral Position unlikely signal
du and Neutral position (NP ) sensor implausible signal
Possible symptoms :
Possible causes:
    Wiring and / or connections faulty
    sensor defective
Possible solutions:
    Check / repair wiring and connections
    Check ( measuring blocks ) / replace Sensor
Error Code: 18441 P2009
  This error code is " Generic OBD " ( for each automaker same description and meaning). The following symptoms / causes /
nl Valve Intake Manifold 1 for Airflow Control signal is too weak
du Saugrohrklappe 1 für Luftstromsteuerung Signal zu klein
and Intake Manifold Flap ; Bank 1 Short to Ground - MIL ON
Possible symptoms :
Possible causes:
    Valve is stuck
Possible solutions:
        fuse (s ) by measuring with a multimeter ( the fuse (s ) sometimes looks fine , but appearances can be deceiving )        fuse (s) replace / replace
Extra info :
    combustion = more economical. link , link . So to see something with the adjustment. Flashy nothing serious as long
    as they are open , it does not cost . And in consumption also is not so bad . This gives no lights etc in the dashboard.
    Read this post on the audiforum.nl
Error Code: 17424 P1016
nl valve for filter bypass valve ( N275 ) interruption
du Ventil für Bypass Klappe Luftfilter ( N275 ) Unterbrechung
and Bypass Flap filter valve ( N275 ) Open Circuit
Possible symptoms :
    unknown
Possible causes:
    ( N275 ) faulty
Possible solutions:
    Check the wiring and all connections
    Check ( measuring blocks ) / replace ( N275 )
Error Code: 16484 P0100 (the corresponding 'old VAG code' is: 00553)
   This error code is "Generic OBD" (for each
   automaker same description and meaning). The following symptoms / causes  / solutions
   are specific to VAG cars; to other car manufacturers who may differ in detail.
nl Air Flow Sensor (G70) supply
du Saugrohrdruck (G70) Anschlußspannung
and Mass Air Flow (MAF) (G70) Supply Voltage
Possible symptoms:
     Probably no real serious problems
     reduced ability
     Infrequent / rough running
     Engine stalls
     Fuel consumption too high
     exhaust smokes
Possible causes:
     This error code is usually caused when you plug the LMM disconnecting and then turn it on contact. The ECU sees no LMM more
     Fuse (s) are poorly connected or defective
     Check whether the MAS is not too close to a) ignition / bobinedraden solenoid valve, c) relays, d) motor
     Bad contacts to / from the LMM (check especially the connection to the ECU)
     Check for leaks past the LMM
     The air filter is clogged (leak in the air intake)
     Exhaust is blocked
     Correct values ​​for the LMM are ao calculated on the basis of the values ​​that pass the MAP sensor. So check the MAPsensor:
     MAP sensor itself
     Leakage to / from the MAP sensor
     The LMM is polluted
     if you use a reusable air filter that is soaked in oil, beware that there is not too much oil is (Just standard)
     The LMM (G70) is broken
Possible solutions:
     Error codes in the LMM are sometimes difficult to solve / able to put you on the wrong track
     Reset the error code, and hope he does not come back
     Before replacing the LMM (G70), first try the following once, maybe it helps:
     Replace the air filter
     make the MAS clean (blow or special cleaner), it does not often, but you never know
     reset error codes
     Check / replace fuse (s) remove the fuse (s) Make the ends of the fuse (s) clean (very light sanding with fine sandpaper, then very little contact spray on it)
     fuse (s) by measuring with a multimeter (the fuse (s) sometimes looks fine, but appearances can be deceiving
     Check the exhaust for blockage
     Check / repair wiring and connections to / from the LMM
     Check for leaks around the LMM
     Check the voltage of the LMM
     Check (measuring blocks) / replace LMM
     Check (measuring blocks) / replace the MAP sensor
     The dealer if there is a software update for the error check
     The ECU, replace but that is the last solution
Extra info:
     LMM (G70)
     Air pressure sensor in the intake manifold / MAP sensor (G71)
     For model years 1995-2004 (?), The TDI VAG a
     bad reputation for the MAS. Which is slowly dirty and dirty (not easy to clean), and loses slowly (!)
     Functionality, somewhat irregular course and loss of ability as a result. The functionality can be tested
     by using [01 engine] a log, [meas.blocks-08], group 003 (3rd gear, floored by 1700-4000rpm)].
I appreciate you taking the time to look at this for me. :P
As a side note, have any of you had issues with wear on the drive shafts? I have had 2 inner cv's done this year and the outer on the O/S is now knocking. :(
Cheers,
Rob.
Just thought I'd let you guys know , the light came back on straight on the first drive after arriving back for the garage.
I've now also had chance to have a quick look round the housing of the ear and throttle body.
There is a rather large amount of oil underneath the egr and throttle bodies.
So I took the intake pipe off the throttle body and there was quite a bit of oil in there, although I did think it's more than it should, this is my first owned diesel car, and I haven't seen any drastic oil burn.
I think it's likely to be a failed egr sensor/body, probably down to the mixture of the coke from the exhaust and the oil from the pre-charge engine rebreather.
Do you guys have any thoughts?
Also, is there anyone around the Buxton, Derbyshire area that has a vagcom cable I could borrow for a few days?
Cheers,
Rob
Hi there, it is probably the EGR valve that needs replacing.
Mine went on a 2008 2.0TDI B7 and replacing the valve fixed it.
It is fairly easy to do if you are in any way mechanically minded.
