Q7 change gears
Hello everyone
Is it possible to force the "manual" transmission on Q7 3.0?
What i mean is that, sometimes i am going down a road at lets say 3rd guear and i want to pass to 4th. In that case i have to accelerate so the rpm´s go higher and allow me to manually put the 4th guear. Is ther any way that i can put the gear no matter what? I mean, when going down the road, if you have higher gear car will gain speed and eventually i would end up saving gas.
Thank you.
Hi Trevor.
No i haven´t. I just have the normal P,R,N,D,S. Where in D i can shitf gears. But the engine does not allow me to shift them at lower rpm´s and i would want when going down the road.
sport will drag the gears out even more. if you don't have a maunal selector option (+ and -) you can try fettling the accelerator to force it to change gear. problem is there will be a predefined revs/torque limit  for gear changes which you can;t get past. only option would be to get a tuner to change the map on the gearbox
Well i do have the +/- option but that option does not allow me to do what i what. I just want to put higher gear that i can for the can to go faster while going down.
What is the secount answer alike that i have. The rpm´s limiter.
in that case your only option is a remap.
no, you need to look for a tuner local to you and see if they can do it
