soft top roof lining
Hi
Just after some advice about a fix
my roof lining has come away around the rear window, has anyone experienced this before and how do you reattach it to the window frame
regards
Ian
Hi there
I had the same problem, and nowhere could I find any useful information. In the end I used double sided tape which seemed to work OK.
Thanks I might try and ask an Audi tech for the answer
I looked to see if there were any clips etc. 9probably the same as you)...........to no avail which is why I ended up using the double sided tape. if you do get an answer from an Audi tech I would be very interested in the answer
