4H 2011 Audi A8L 4.2 FSi front Brake Discs correct ATE part numbers
Hello all
As a newbie to the Forum, please be easy on me.
i am having trouble finding the correct Front ATE disc Part number for my 2011 D4/4H Audi A8L 4.2FSI.
some sites like Autodoc state article number for my vehicle as Article Number  24.0134-0103.1 356,00 mm vented 1 LL
but if i search on ebay some sellers say this is not compatible.
Can anyone in anyway help to assure me this is the correct fitment. Audi do not want to help!
secondly are there  and other disc manufactureres i should and could look at other than ATE?
ONE
thanks Paul. only sems to show rear axle and one BOSCH front disc.
I willl keep searching
In the boot under the spare wheel you have a build sticker with PR codes
Enter them here to decode, it will tell you what disks you should have
http://prsearch.planetvag.com/
i asked my brother earlier to check as i have seen this been mentioned on another site, but i have no spare wheel as its the Long Wheel Base version, unless its else where which i will have to look for later.
Thanks though i aprecaite the tip!IMG-20180712-WA0030.thumb.jpg.743ae26e02c00e9c2eca677e496e6780.jpg
Yes take that foam inset out , its there underneath 🙂
Hi,
I do not no anything about the part but try to call Audi on 0208 380 4000. There parts department will help you parts number etc.
Good luck
