Q7 Dash-Cam fitting advice
Hello from a newbie and learned advice appreciated. Have a new Q7 and swapped over a Next-Base Dash-Cam used in my last car.  Used hard-wire kit which has piggy-back fuse adaptor. Seems all fuses (passenger foot well) are constant and so Dash-Cam on all the time.  Last car had switched fuses which went off when ignition off.  Does anybody know if current Q7 has any switched fuses? Dash-Cam leaflet says has a cut off if battery level very low, but not keen to risk.  Thanks in advance for any advice.
I have mine wirred in on my a6 c6 to the heated windscreen sprayers . Its only on when ignition is on. But the only way to check is to get a multimeter and check voltage on each fuse with ignition on/off
  • 1 year later...
