A3 I Need A Clutch But Do I Need A Flywheel?? HELP!!!!
Hi,
i have a 2004 (53 plate) Audi a3 2.0 fsi , my clutch started to slip last week, need a dual mass clutch, but do i need a flywheel?? My bro in law said i may need one , i dunno what to think
HELPPPPP
Hi Aaron
If the clutch has started to slip then chances are you would need a dual-mass flywheel as well....you could check the freeplay when the clutch is removed but if it is showing signs of excessive movement (wear) then it would be prudent to replace it at the same time
