Timbo1979
2.0 tdi smoking issue
Having an issue with my 2.0tdi audi 07. It’s blowing white smoke that smells like diesel/paraffin but only on tick over if you rev it the smoke clears. I had the turbo changed a year ago but have started hearing a whistle when putting my foot down and have had the egr off and cleaned it as was solid but still this white smoke. This is my first diesel and having owned it just over a year it’s starting to drive me nuts and help or info would be greatly appreciated
Share this post
Link to post
Hello Tim,
The symptoms you describe are typical of injector/s issues, although could also be other faults.
If this were mine, I would be seeking out a trusted local diesel specialist rather than a normal local garage. There is a fairly simple basic test for the injector efficiency.
Share this post
Link to post
injectors   bud as said
Share this post
Link to post
had same problem with mine  sorted out with changing injector
  • Thanks 1
Share this post
Link to post
plus if one of the glow plugs is worn this happens to
Share this post
Link to post
Glow plugs just come in circuit at temperatures below 5 degrees C, Kev? My money would be on a simple leak-back test on the injectors.
Share this post
Link to post
Loading...
