Looking for guidance where to find a power steering pipe for my 2002 TT, part number 8N2 422 8910
Yes that is correct, it is the first place I looked plus I have tried using 1st Choice as a means to access salvage parts.
Thanks Roy. Did your local Audi dealer say the part was obsolete? If so, did they suggest that there is a system whereby they can search/alert all dealers (UK and foreign?) to see if it might be available anywhere as unused stock.
TPS ? - the VAG specialist suppliers.
Partsfinder? - similar to 1st Choice.
Specialist publications such as Modern Classics (there are more).
Is there a TT Owner’s Club?
If all of this fails, then try local hydraulic hose suppliers ( commercial vehicle) who may/should  be able to make something up for you.
I have used TPS many times but on this occasion I am out of luck. I have a live searches still open on Partsfinder and 1st Choice. For the most part the pipe is metal with some flexible (rubber) sections. It failed at a fixing point due to corrosion (a common failure point in older cars) so I am advised. I believed this forum is linked to the UK TT Owners club?
Hello Roy,
Apologies for suggesting routes you have already been down, but I have also included are a couple of additional ideas.
If this were mine, I would be looking up commercial vehicle factors and paying them a visit armed with your defective pipe. They are likely to point you in the direction of hydraulic specialists who can probably remake the pipework for you.
Hi Gareth, not a bad idea to try independent hydraulic specialists - cheers
pertex down team valley  gateshead     done one for my mate  30 quid  it cost
Cheers, I will give them a try
  • 4 weeks later...
As my children would say, "Google is your friend".
At least you would be pointed in the right direction of hydraulic pipe repairers, best of luck.
I tried Pirtek, unfortunately they could not copy the heavily corroded pipes so now the plan is to have them fabricated in flex and fitted direct to the car.
