Rear camera install
Chris j 1980
Hi it depends which camera you have, you normally have the rear view camera as an add on with Nextbase or Blackvue, if you look on youtube the rear install is pretty much the same for any vehicle is all you need is a good set of plastic trim removers and some patience, the only advice I can give is try and run your cable down along the sill trim as much as possible as if you run it along the head lining all the way it will kill the DAB radio signal, when it reaches up to the head lining in the rear you may have to buy some ferrite core to cut ou the interference from the rear camera.
Chris, it might be worth contacting a specialist company in your area and getting a quote for fitting a rear view camera.
I had a dashcam hard wired into my own Audi A4 Avant (B9) soon after I bought it.
Regards,
Chris
