Audi Cabriolet repairs
David Reid
Does anyone know of a ‘repairer’ of soft-tops…..I have an Audi A3 Cabriolet (2010)
and the mohair top is coming away from the back window . I am told that the only
way forward is to replace the top (for £5000?). Any advice welcomed.
Hi use black Tiger Seal very carefully in small quantities tape off the surrounding area with masking tape and smooth it off with a teaspoon dipped in white spirit, the Tiger Seal grips like there is no tomorrow and fills the gaps where it has come away and remains very flexible after curing.
  • Like 2
Hello David,
Certainly as Steve says in my experience. One tip which may be useful, is to mask very carefully, but remove the masking tape immediately you have done a reasonably small section. Don’t leave the masking tape any longer than you have to once you have a nice smooth and even surface, otherwise removing the tape tends to lift the edges of the Tiger Seal.
