Any ideas.
Been having trouble with coolant loss and bad oil smelling smoke from the exhaust since buying my audi a3 2.0 tdi 170. I recently notice oil/water spitting out of the front of the engine.  Ive included a video to show so any help would be appreciated.  The car is 2007 model
first thought is blown head gasket. video does not work for me
i.e it does not run only shows a static picture of engine
I too see only a still picture.
A blown head gasket is also my first thought, though other explanations are possible. Are there other symptoms such as emulsion in the oil, overheating, oil loss?
Hi check behind the cam belt cover as it could be a leaking camshaft seal the angle of the oil throw from the belt looks about right and iff its sucking air into the head area that would cause the smoke as the crankcase pressurising would cause excessive amounts of crank gas to go into the PCV system.
i can see oil or water being blown out .. but at the same time ?
guess this one is for the experts to comment on.
i will watch this one with interest.
ken
Just now, Leight123 said:
No there is no muck in the oil or overheating or oil loss
Ill get this checked over the weekend.  Its driving me mad now tbh.   Thanks for the input
It does have a bad idle every now and again aswell
Hi it sounds like a failing injector or a sticky EGR best to get it scanned for codes.
