Audi A8 D2 4.2 ABZ - Timing belt
Hi all, well am planning on doing the timing belt soon -ish ! I have got the big bar to lock the pulleys in place. Now starting to shop for the belt . tensioner etc.
Any help from anyone who has done this before will be welcome.
Cheers.
ebay best bet bud
Thanks Kev, I meant any assistance as in 'Hints & tip' Best reliable sources ? To ensure correct part numbers etc ?
Hello Mathew,
My suggestions will relate parts rather than procedures:-
If you aren’t buying genuine VAG parts at discount, then I would suggest you buy Gates kits which will include belt, tensioner and water pump (if belt driven).
As Kev says, EBay would be one source, but if I was in your situation, I would want to ensure that what you buy off EBay is not ‘old stock’ , since belts should be renewed every five years, and you could find belts may already be a couple or 3 years old before they are even fitted!
I have used Car Parts in Motion to good effect and at reasonable prices, so it might be worth checking there. I would also renew the serpentine belt and tensioner at the same time.
Hope some of this helps.
13 hours ago, Magnet said:
Hello Mathew,
If you aren’t buying genuine VAG at discount, then I would suggest you buy Gates kits which will include belt, tensioner and water pump (if belt driven).
I have used Car Parts in Motion to good effect and has reasonable prices, so might be worth checking there. I would also renew the serpentine belt and tensioner at the same time.
Thanks for that Gareth. I will have a look . Cheers. 🙂
