Strange noise from engine bay or...gearbox
Ok, this noise is hard to describe, but I'll have a go.
Car starts and drives no problem. No issue with gear changing. However, when I stop at a junction, or pull into my drive (I am moving slowly) there's a sort of hollow noise, almost a slapping, but more of a whawhawha noise. If I put the car in neutral or park it stops.
Put it back into drive and it's there again.
But only after I've been driving.
Is it transmission fluid, something loose, a worn belt?
Any ideas? I'm going to have to take it in, as I don't want it getting worse.
Ta.
Sorry...it sounds like it's coming from under the car towards the engine bay.
Sounds like a belt tensioner or alternator clutch.
Cheers. I did think it was a belt. I'll get the garage to look at it and let you know.
I'll try to record it tomorrow
This is the noise! I'll get this sorted, the car is driving like a dream at the moment, so I'll get this done...asap
