P173A – Position sensor 1 for gear selector, implausible (HELP)
Hi Guys,
I had a new clutch put in about 3 months ago and my gearbox serviced about 7 months ago.
My car is acting like it doesn't know what gears to pick at any point you try to put your foot down?
I took it to a garage and they said its an intermittent error  -
P173A – Position sensor 1 for gear selector, implausible signal
I have shipped it to ECU Testing and they have said there is nothing wrong with the unit and it has passed its tests.
They say It might be a sensor issue to fix, has anybody heard of this before?
Best wishes,
43 minutes ago, cliffcoggin said:
Is this the same problem you wrote about on 7th September? If so, what did you do about the Mechatronic control?
Hello, yes it is the same problem.
I took it to a garage to diagnose and got the sensor issue.
Since then I took out my mechatronics unit and shipped it off to ECU testing to see if they could fix it. They say there is nothing wrong it and it works as it should. Im starting to think either the magnets in the gearbox may have broken but I have no idea where to get those fork magnets from...
